Previous in Forum: Pump Design   Next in Forum: Can Anyone Sharing Some Idea to me?
GD^2 Value Calculation
10/27/2010 8:10 AM
GENTLEMEN, Thanks for the information on the above subject. But there is still a lot of confusion in this matter. When I calculated as per the table I din't get the required value. I would like to send the drawing of the component for which please explain actual method of calculation. regards P.M.M.KRISHNA MURTHY.
Re: GD^2 Value Calculation
10/28/2010 6:18 AM
To vague ...not enough info ...as per normal!
Post the data your inputting ...including all calculations....and your results
You can also post the drawing on here if you want.
It seems that J ( MOI ) =GD^2 / 4
So GD^
2 = J * 4
Regards Woody
