Previous in Forum: Choosing the Right Controller for AD Signals Processing   Next in Forum: Offline SMPS
9 comments
Utilization Factor Demand Factor
10/28/2010 1:33 PM
Can someone give utilization factor and demand factor for
socket
heating
lighting
motor load
Good Answers: 140
Re: Utilization Factor Demand Factor
10/28/2010 3:21 PM
Lets see...
We utilize "socket" when we plug something into it.
We utilize "heating" when it is cold out.
We utilize "lighting" when it is dark out.
We utilize "motor load" when our motor does some work.
And we demand "sockets" to plug things into and a "heating" system if we live in cold areas. Having "lighting" to enjoy our heating system is also a demand of ours. As to motors... we demand a motor to move air in our heating system.
Bottom line... useless questions get useless answers.
10/28/2010 3:52 PM
I do not believe this guest will be an asset on our submarine excursion.
Good Answers: 97
10/28/2010 4:38 PM
He wanted to confiscate the compass I got in the Cracker Jacks, so I swallowed it. Ornery devils!
CRTL-Z
10/28/2010 5:13 PM
I'm not so sure. Weren't we looking for a torpedo test pilot?
And he certainly outwits this guy: Experiments Done in Space
10/28/2010 5:23 PM
Torpedo test pilot... That's pretty good!
Unredundant, could we use that compass? I do not know if our new crew member has one of his own.
Good Answers: 97
10/29/2010 9:14 AM
I'll have to get hold of some prunes.
Hey..you guys wouldn't happen to be looking for Hollywood?
CRTL-Z
10/29/2010 8:40 AM
IEC BS NEC different definitions
UF is mainly used for load cal in europe and countries following standard
DF is NEC term and applied to individual loads
both of them <1
for further refrences please see T A short book on distribution
,NEC 2008 ,
organizations develop these based on their experinces so dont get confused
Correct me if i am wrong i am learner
10/30/2010 1:41 AM
it is same definition, depending which standard you are using
for the values you are asking about, I guess you are calculating the required power of a building, it depends on the number of deviceconnected, if you have only one heater than your factor is 1 , if you have 100 for example it can drop below 0.5
regards
dont say it, write it
10/30/2010 6:12 AM
hi
for lighting 1 DF
for sockets it is 0.5
for motor it is 0.8 but again check the largest motor *125 % more
heating it is 1 if >40 use 0.5 factor
Anonymous Poster (1); Doorman (2); ikhanuk (1); Le_Noble (1); lyn (1); North of 60 (1); Unredundant (2)
