Previous in Forum: Lincoln Navigator Air Suspension   Next in Forum: All Season, All Weather, or Winter Tires
Wont Go in Reverse
10/29/2010 3:07 PM
Hey i have a 94 hyster 4k electric forklift that wont go into reverse any ideas
Re: wont go in reverse
10/29/2010 3:21 PM
avoid corners?
Charlie don't surf.
Good Answers: 140
10/29/2010 4:21 PM
Check...
Fuses, limit switches on the controls, contactor coils and grounding.
Good Answers: 58
10/29/2010 4:24 PM
"avoid corners?"......and dead ends!
But seriously, I can think of a few things to check:
1. The forward/reverse shifter, check linkage to switch and check switch itself.
2. Check the reverse solenoid.
3. Check the forward/reverse interlock (locks out forward solenoid while reverse solenoid is pulled in and visa versa).
4. If you have a double winding traction motor, check for an open reverse winding.
5. Check wiring, fuses, and circuit breakers between all points listed above
Off the top of my head, this is all I can think of. It's been a few years since I serviced one.
It is an electric fork lift, it must be an electrical (directly or indirectly) problem.
KJK/USA (1); North of 60 (1); stevem (1)
