Previous in Forum: Fatigue Calculation for Pressure Vessels   Next in Forum: Grease Ronex MP - Operation Temperature Range
Pipeline Management & Maintenance.
11/02/2010 3:13 AM
Hi everybody,
The water production lines were pigged from the water collection manifold at the CPF Plant towards each well site.
Each line at the manifold is equipped with a blind flange. Each line will be isolated and depressurized and an isolation ball valve will be installed that will allow connection of the mobile launcher. At each well site, the end of each line is equipped with a blind flange. Each line will be isolated and depressurized and an isolation ball valve will be installed that will allow connection of the mobile receiver.
As a minimum, the following pigs are used for each pig run of water supply lines:
- Proover pig.
- Bi Di pig.
-Bi Di brush pig.
We have used firstly the mechanical pig run in order to get the maximum debris collection and progressively we check the cleanup degree of internal pipeline.
The chemicals used for the water source lines cleaning will be 15% HCl mineral acid, neutralizer, and high viscosity pick up gel.
The second stage, we used chemical pig train (HCL solution) which carries solids and any residual from the pipe wall HCL will penetrate iron sulphide, iron oxides, mineral deposits, & sand to break up dense deposits.
The pig train velocity is constant at a speed of no more that 0.3m/second to allow sufficient contact time for the chemical to penetrate and remove solids.
The objective of these runs is to progressively clean the line to remove scales & corrosion debris.
Regarding all Photos of each run pig on receiver, it is clear that water source well is suffered by bacteria/H2s Corrosion Problem (see attached photos).
Is it sufficient this pig procedure as defined or shall we biocide treatment added in order to kill bacteria along the pipeline?
I appreciate a quick answer and thanks a lot in advice.
Best regards,
Good Answers: 181
Re: Pipeline Management & Maintenance.
11/02/2010 5:33 AM
I'm not a water engineer, these are just my thoughts.
If you are responsible for the supply of potable water and you thing there may be bacterial contamination, you are duty bound to do something about it.
NOTE, it's your responsibility!
11/04/2010 2:57 AM
Thanks for your replay, one more information it's concerned water that generaly used in water injection wells of oilfield sytem.
11/03/2010 2:46 PM
Potable water? Once the line has all the debris removed, fill with clean water and chlorus to 40ppm, leaving for 8 - 24hrs (depending on local regs/requirements), then flush back to potable levels, leave another 24hrs and take samples for bacterial testing. Once they are tested as clear, the pipe can be put in service.
Madness is all in the mind
Register to Reply 3 comments
GM1964 (1); musame (1); TonyS (1)
You might be interested in: Line-shaft Spools, Power Line Network Components
