Previous in Forum: I Tried to Be Green!   Next in Forum: Measuring Volume of Beans Over Time During Soaking
Bridle Loop
11/03/2010 4:11 PM
Can anyone tell me what a "Bridle (Bridal) Loop" is in relation to piping hot water to a VAV reheat coil?
Re: Bridle Loop
11/03/2010 5:30 PM
I don't have a clue. But, I'll guess anyway. Maybe it's another term for closed loop circulation within the VAV unit?
Good Answers: 19
Re: Bridle Loop
11/04/2010 6:24 AM
It is also called a nulling loop and maybe a bypass. It will allow circulation after a 3-way valve is closed.
There's a theory stating if anybody discovers exactly what the Universe is for & why it is here, it will instantly disappear & be replaced by something even more bizarre & inexplicable. There's another theory stating this has already happened.D Adams
Good Answers: 61
Re: Bridle Loop
11/04/2010 8:53 AM
GA to Geode Hunter. For more information, a very good description and drawing can be found here.
Re: Bridle Loop
11/04/2010 1:37 PM
Thanks so much. Makes perfect sense. I'm not sure of the origin of the term...why not just call it a bypass?
bs
Good Answers: 19
Re: Bridle Loop
11/05/2010 6:18 AM
[quote]
[quote]
I am not so sure on why, but there are many other items also called the same. Horse trails in local parks have similar names and usually are a shortcut to the barns or campgrounds.
I believe it also is some part of the leather tack and harness that probably looks like a bypass from one section of tack to another.
Most likely some mechanic was trying to spice up his day and the term caught on.
Re: Bridle Loop
11/04/2010 5:28 PM
Just a guess? In a system that has separate pairs, that are joined together, they are referred to as married, eg: marry system A to system B. ( Join them together).
Regards JD.
Register to Reply 6 comments
Geode Hunter (2); jdretired (1); Littleton Engineering (1); lyn (1); pwr2thepeople (1)
