Previous in Forum: How to Edit iPhone, iPod MP4 video?   Next in Forum: cone crusher(11.4)
reprogram your engine computer by Car Deal Expert</a>.
11/04/2010 12:51 AM
So your engine computer needs reprogramming Your engine's computer needs to be flashed, or reprogrammed after being erased, if you would like your engine control modules (ECM's) to stay up to date all the time. Microprocessors within the power train and fuel injectors have to have this done if cars are older newer than 1996 since the system won't work properly otherwise. When programming is up to date with anything, your engine works much better. It's a bountiful cash crop for repair shops, who tend to charge between $ 80 and $ 120 for the service, according to Under hood Service. Your car can be flashed by you if you have the right equipment around. Article resource - How to reprogram your engine computer by Car Deal Expert
How reprogramming an engine computer works
If you want to reprogram your engine computer yourself then you should be able to find the diagnostic port under the steering wheel inside the car which you will attach a special scanner to. The auto manufacturer has put new programming into this scanner which erases the old and replaces with the new. Back within the day, the reprogramming process involved removing different parts from the car, but now an USB cable, scanning device, and a quite good Internet connection is all that is needed to work with the diagnostic port. The ECM ends up having new software flashed on in with info coming from the site the manufacturer puts together.
When an ECM should be flashed?
It could be a good idea to listen to auto shops who suggest flashing the engine every few years. When you notice your car needs to be updated on its programming, then it's a good idea to do the flashing then, although if there is a recall then having your car flashed is necessary. Routine maintenance shouldn't include flashing when doing every little thing else to make certain your car works.
Using a DAY flasher to do the work
This is fairly easy. Take a look at the vehicle manufacturer's website to see if any software updates are available. Download the update into a flash programming device. You may need more software if you want to have a proper engine turning. Websites like DIYEFI.org can help you get more information on the subject. States like California that have tough emissions testing might have special laws outlawing some different aspects of engine programming, so make certain to check with your state's motor vehicle authority first.
Get a new car with no ECM programming problems with an automobile loans
Further reading
Underhood Services
underhoodservice.com/Article/39556/flash_reprogramming_vehicle_computers.aspx
Scotty Kilmer on reprogramming your car's computer
youtube.com/watch?v=Mc0aMxSdat4
DIYEFI
diyefi.org/index.htm
Re: reprogram your engine computer by Car Deal Expert</a>.
11/04/2010 5:38 AM
Crass commercialism at its worst.
Go flash yourself!
11/05/2010 12:57 PM
Old Scotty needs it because he drives a ford. poor fella.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
Register to Reply 2 comments
