Previous in Forum: How to Increase the Efficiency of the Petrolium in Cars   Next in Forum: Modern Motor Oil Can Damage Some Older Engines
11 comments
Adjustable Time Delay Relay
11/04/2010 8:15 AM
Hi guys .
Long time we don't have contact.
I'm looking for adjustable time delay relay 12VDC for automotive applications.
It means that the dimmenssions must be small .
Any suggestiosn????
The only reason to stay and keep alive its keep getting better........- Wilf
Good Answers: 299
Re: Adjustable Time Delay Relay
11/04/2010 11:16 AM
Can you repurpose an intermittent windshield wiper switch?
11/04/2010 11:23 AM
I can not , i need a fixed output contact , not intermitent
Good Answers: 299
11/04/2010 11:31 AM
Fixed output...
Do you mean a one-shot timer? Rather than keep guessing, can you tell us more exactly just what you wish to accomplish? What is/are the time cycle, the start and stop mechanism, operate with car running or not... those sort of things.
11/04/2010 12:16 PM
Its a time delay relay ( on delay ) 12 vdc , 0 to 120 or 180 seconds adjustable delay time .
I prefer dimmenssions similar to common automotive relays.
Good Answers: 299
11/04/2010 12:33 PM
I think RDGRNR has the right idea. Get a base for it, mount where it will not get wet, and continue with your project.
[edit] "... but its to expensive." price limitation in place would be a useful piece of information. How much is "to expensive"?
Good Answers: 29
11/04/2010 12:00 PM
Are you looking for something like this?
Good Answers: 38
11/04/2010 12:29 PM
In Google I searched "automotive time delay relay" and came up with tons of hits. Now you just need to pick whether it is normally open contacts or normally closed. Or both.
Try under that search title.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
11/04/2010 12:35 PM
Simple .
I need a NO contact that energize when i star the engine but close the contact after time setted .
I just found it at MRS Electronics in Germany but its to expensive.
I need to find it in US .
Good Answers: 123
11/04/2010 12:54 PM
I have some from Amprite, at www.amprite.com. I have been buying them from Allied.
These are delay on break. I also use some delay on start ones from NCC. National Controls Corp. 800-323-2593. Also from Allied. These are 2"x 2" x.5" they are low current (1-2A) so use load carrying relays with them. The on delay is cheap. The off delay is about $30. Try www.alliedelect.com. Good luck.
Bob
Good Answers: 58
11/04/2010 1:43 PM
Sign of the times. Since this can be used for a car bomb, I'm not replying.
mike k
11/05/2010 12:58 AM
AMEN
Register to Reply 11 comments
Anonymous Poster (1); bob c (1); charsley99 (1); Doorman (3); mike k (1); RDGRNR (1); VIP (3)
