Previous in Forum: API 650 Tanks   Next in Forum: Transmission Pressure
Chainsaw Repair
11/04/2010 9:18 AM
i need to fix the recoil spring on a husquavarna xp chainsaw. it retracts until i screw it in place. once i pull the drawstring it wont retract wtf am i doing wrong???
Pathfinder Tags: chainsaw
Re: chainsaw repair
11/04/2010 9:47 AM
Check the pulley , I recently had the same problem. Turned out to be the pulley was cracked around the hub on the back side , that caused it to drag against the housing and not retrack when installed. Bought a new one on e bay for a couple bucks. Hope that helps you out.
Michael
United Kingdom - Member - British
Re: Chainsaw Repair
12/28/2010 4:21 AM
Put some washers between the pulley and the body of the chainsaw, so that it gives the pulley a bit of space to move; As long as it still engages with the flywheel it should work.
bondy111
Register to Reply 2 comments
