What happens to the voltages induced? And which values will be constant?
If voltage induced is constant it means the current will increase and this will probably lead to saturation at core, true?
İf current increases it will slightly cause a voltage drop on primary and the voltage induced will decrease. What is the final value considering the assumption above? (flux ,and then current increases due to the decrease in frequency)
Or the voltage induced is not constant?
What would be our leading assumptions while trying to understand this case?
