Previous in Forum: Engine Coatings   Next in Forum: Yamaha Crux Wiring Diagram
11 comments
2000 Cavalier Won't Start
11/07/2010 7:58 PM
2000 cavalier won't start....changed wires and it is getting spark also changed fuel filter and fuel pressure regulator. sprayed starting fluid in throttle and it starts and stops when fluid burns out. if i hold my hand over throttle body to "choke" the motor it tries to start but shuts off. is this a air control problem and if so what sensor needs replaced or is it something else?.
Good Answers: 145
Re: 2000 Cavalier Won't Start
11/07/2010 8:07 PM
Please do a search on Cavalier in the Search all of CR4.
There have been so many requests for remedies on cavaliers that the search will give you more information than a factory service manual.
11/07/2010 8:16 PM
PASSLOCK!!!!
11/07/2010 9:50 PM
PASSLOCK MY ASS
11/07/2010 10:14 PM
never use starting fluid in a fuel injected car
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
11/07/2010 11:03 PM
So call a mechanic or AAA.
Good Answers: 123
11/07/2010 11:33 PM
Check out some of the past threads on checking the electric fuel pump. If you can not find them, just post back, and I will help you. Good luck.
Bob
Good Answers: 60
11/08/2010 8:11 AM
11/08/2010 12:10 PM
Electric fuel pump?
11/08/2010 1:01 PM
Have you checked the timing belt? It might be out of time.
“If you forget you have to struggle for improvement you go backward.”
11/08/2010 1:41 PM
Nah it's got to be the cigarette lighter has been stuck in place and drained the battery.
11/08/2010 2:09 PM
Ah yes, the old cigarette lighter stuck in place malfunction. How could I forget about that.
Anonymous Poster (3); bob c (1); darren2264 (1); mrclean (2); peterg7lyq (1); redfred (2); Tobugrynbak (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
