guys can you get me started please? i have an assignment and i am not really sure how to start to be honest.
it is intended to supply a 3 phase 22kw motor using copper pvc cables.the motor has assisted starting in the form of star/delta starter mounted in an mcc, housed in a substation 50m away from the motor.the efficency of the motor is 90% and power factor is 0.77,find................
1. full load current so is this then?
I=Power in kW/(sqrt of 3 x voltage x power factor)
I= 22 x 10^3 / Ö 3 x 415 x 0.77 x 0.9
I = 45.34amps.
2. power input: a bit confused with this if its a 22kw rated motor is this not the power input?
3. current starting on star?
any advice appreciated.
