Previous in Forum: Requirement of Line Bay   Next in Forum: Formula of Calculating Output of a Steam Turbine
The Automatic Mains Failure Panel
11/12/2010 11:49 AM
Plz everyone.. i'm working this project.."the design and construction of a 32A micro-controlled based automatic mains failure panel". Any ideas on where i could get the circuit diagram and the tips on programming the micro-controller? thanks alot...
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: The Automatic Mains Failure Panel
11/18/2010 8:14 PM
In three-phase applications, if low voltage is available in any one or two phases, and you want your equipment to work on normal voltage,this circuit will solve your problem.
