Previous in Forum: Job Search   Next in Forum: Static Pressure
9 comments
Patch Panel Rack and Assorted Things on the Rack
11/17/2010 7:26 AM
The above is a "working" AV, Data, telephone and on demand movie patch, equipment,
DVD players, Hubs, modems, routers and many other "things"
power supply panel. It is working all over the estate. Question have you seen worse I have been asked to organize (make it pretty). The only problem I see is that the cabling entering the room from the conduits is not supported and Is hanging from the conduit elbows. I have told the customer that the system is working so leave it as is, the house hold staff know the system. I told the owner we only needed to support and secure the cables entering the room so they are not hanging by their own weight.
Comments or suggestions ?
Re: patch panel rack and assorted things on the rack
11/17/2010 8:19 AM
The Owner is correct. This installation is a mess and should be cleaned up. If you are not up to the task at hand, just say so. Have the Owner bring someone else in.
I would add another smaller box for the telephone CAT3's to the right outside the CAT5 Data.
Bundle the spaggetti then use wire ties to hold them after removing all that do not terminate to anything.
Get rid of the allegator clips! Very tacky, ugly, and poor implementation.
Label everything.
Re: Patch Panel Rack and Assorted Things on the Rack
11/17/2010 8:55 AM
Ugh!
For a start, please review this Cable Management article.
11/17/2010 3:07 PM
Hey where I work that would be considered pristine. After two decades of post-doc experimenters running wires in cable trays and never removing them you would be stunned what most scientists think about good cable management. It does make troubleshooting interesting. Most of the time a wiring problem is a black wire, unless its a grey wire.
11/17/2010 5:54 PM
"Most of the time a wiring problem is a black wire, unless its a grey wire."
Sometimes the trouble might be the yellow wire...
Imagine trying to make a change to this rat nest.
Found this image on the net. Looks like a posed photo... can there really be cablers/IT guys who would do something like this? And feel good about it?
11/17/2010 11:00 PM
it looks like you could heat the house with that mess. the guy has $ and wants it pretty,bring in a good electrician not an AV person. who ever did this should be shot.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
11/18/2010 1:14 AM
Looks mighty fine compared to some computer rooms I've seen over the last 30 years. You might clean it up a bit, but unless they supply you with INTENSE diagrams, I'd leave it be. It works, the staff knows it and if something happens and a link or station goes down, guess who'll get blamed.
Good Answers: 61
11/18/2010 11:36 AM
I would recommend NOT using cable ties on patch cables, or data cables of any type. Compression of Cat5 or higher cables can damage the conductors, and any fiber will likely fail.
If the owner wants it to be neat, and the house staff needs to be able to reconfigure connections occasionally, I recommend using a simple cable management system such as Panduit. Attach your favorite flavor of channel or ring to the outside of the rack and route all cables through. Some patch cords will need to be replaced due to the longer route, but it's worth the effort. Cost is minimal and it makes identification and maintenance so much easier.
Canada - Member - New Member
11/22/2010 1:36 PM
Have a Happy! ;-)
Good Answers: 19
11/22/2010 10:55 PM
It's neater than this one, but of course, this is a circuit breaker panel:
Anonymous Poster (1); Bud (1); darren2264 (1); Doorman (2); Loupy (1); ParadisoFinale (1); pwr2thepeople (1); redfred (1)
