Previous in Forum: Ammonia Hitting 20C-50C   Next in Forum: Epoxy Floor Coatings
Test Methodology for Polyethylene Seals
11/17/2010 5:05 PM
I am in the process of developing a repeatable test standard for testing seals of 1.5-2.0 mil LDPE. These seals are manufactured with a hot press and have a tendency to be variable if the manufacturing process is deviated from. In thinking through the development of the test standard, it appears as though suspending a sample in a fixture and attaching a weight to the opposite end will allow me to perform a "snap" test by dropping the weight in a controlled manner.
My questions are:
-Is there a current ASTM standard (I've searched with zero results) that might reference a test similar to this?
-In application, is the "snap" test the most repeatable test that could be conducted?
-I will be required to test samples along a radius, will a deviation in setup or methodology be required?
As always, time is of the essence since they wanted this yesterday. Thanks in advance for all of your help
...just another day at the car wash...
Good Answers: 52
Re: Test Methodology for Polyethylene Seals
11/18/2010 11:22 PM
Your weight-dropping concept does smack - to an extent - of a Charpy impact test. The ASTM has some recent revisions that could possibly be useful. An example:
ASTM F2231 - 02(2008) Standard Test Method for Charpy Impact Test on Thin Specimens of Polyethylene Used in Pressurized Pipes
is worth a look to see if you could use it.
Mark Bingham
Relativity PL
11/19/2010 6:33 AM
Thanks Mark, I will take a look at it.
Good Answers: 58
11/19/2010 7:51 AM
Please let us know what you are attempting to test the product for. Do you want to perform a leak test, static strength test, dynamic strength, etc.?
11/19/2010 8:16 AM
We are using a hot press and dyes to place seals on different widths of tube stock. Our seal parameters are 300 F with a 4 second dwell.
We are trying to further determine a quantifiable method in which we can have our manufacturing department test the seals to ensure that our quality standards can be met.
Ideally, we would like to utilize a pressure test to verify seal quality, but in the short term we are looking at attempting to utilize a seal strength test of sorts.
Good Answers: 27
11/19/2010 9:44 AM
You might take a look at ASTM D2000 and the associated test methods.
11/19/2010 12:25 PM
Thanks! We found some methods we are looking into.
Register to Reply 6 comments
BGCW (3); Bluestone (1); Relativity PL (1); welderman (1)
