Previous in Forum: Electrical Connections Two Pole Spade Connector   Next in Forum: Need Mathematical Help to Compute Magnetic Force
8 comments
Why Copper Ground Rod?
11/23/2010 6:33 AM
hi, All
why copper ground rod?
regards
Re: why copper ground rod?
11/23/2010 6:44 AM
Gold is too expensive.
Copper is a good conductor.
11/23/2010 7:06 AM
hi
i think it resistance is verylow that's y we are using copper rods for gronding.
Good Answers: 131
Re: Why Copper Ground Rod?
11/23/2010 3:36 PM
Most ground rods these days are actually copper-clad steel: copper for the conductivity and steel for the strength when you drive them into the earth. If you tried to drive a solid copper rod, in many cases it would look like a pretzel before you got done.
11/23/2010 6:12 PM
Hi, All
For installation of grounding rod or grounding system, check with your local requirement or NEC code of practice.
regard's
11/25/2010 6:38 AM
Due to its conductivity and corrosion resistant properties.
pnaban
11/28/2010 1:31 AM
Which is your country?...I want to know where is copper rod using as earth rod. I can make some money out of that...just need some digging
11/28/2010 1:34 AM
miniature copper mines?
Good Answers: 130
12/19/2010 9:47 PM
Australia went to stainless steel some time ago. Usually installed with a salt absorbent.
34point5 (1); Anonymous Poster (3); kramarat (1); PeterT (1); pnaban (1); russ123 (1)
