Previous in Forum: Rigid or Flexible Busbar   Next in Forum: Standard Limit for Contact Resistance of Siemens LV/MV Circuit Breaker
10 comments
Loss of Color on my TV
11/23/2010 5:32 PM
My television had lost it's color and now everytime I switch on it is on black and white. can someone tell me what the problem is and how to solve it?
Re: tv
11/23/2010 5:40 PM
Barnaby, is this the Panasonic TV you had trouble with a little while ago?
Re: tv
11/23/2010 5:56 PM
You know we can't possibly do anything without the Model #, Serial #, and Date of manufacture.
If we don't get that information, you'll be staring at that flippin' red dot forever.
Good luck.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: Loss of Color on my TV
11/23/2010 6:23 PM
Check with your local opthamologist...
Sometimes my thoughts are in a degree of order so high even I don't get it...
11/23/2010 6:30 PM
Many of us here - even you yourself - can tell you what the problem is: ".... now everytime I switch on it is on black and white". The solution is more tricky.
1) Check the signal input connector.
2) See #2.
11/23/2010 6:57 PM
Have you tried tv land, I Love Lucy, Leave It To Beaver, Andy Griffith and many others look great in black and white.
Also, unless the fix takes less than 15 minutes and parts, (which you won't be able to find), cost less than $50, you can get a new tv for less than repair...............I've been there.
11/23/2010 7:13 PM
The problem is that it is broken.
The solution is to replace it.
11/23/2010 11:11 PM
get a magnet and scratch on monitor wonders happens
11/24/2010 1:41 PM
Without any further information the only thing that comes to mind is that you are using an S-video source and the chrominance channel is bad somehow. Check/replace the cable. (As opposed to composite video, which uses a single connection for both color and brightness signals, S-video uses two connections : Luminance for brightness and chrominance for the color)
Charlie don't surf.
11/24/2010 6:29 PM
what colour are those wires. i'd like to do a physical check and replace any of them.
11/25/2010 2:20 AM
Replace the color cartridges.......or your son might be sold the color Tv and replaced a similar black/white.
Register to Reply 10 comments
Anonymous Poster (4); ChaoticIntellect (1); Doorman (1); JohnDG (1); kramarat (1); lyn (1); stevem (1)
