Previous in Forum: Will Bolts Be Significantly More Brittle in Moderately Low Temperatures?   Next in Forum: Materials That Are Transmissive To White Light, But Not Infra-red?
CO2 Corrosion Rate
11/23/2010 9:02 PM
i already go-through some article regarding to co2 corrosion rate on carbon steel material but still didn't get the effect of co2 corrosion rate at superheated temperature(300 degree c).what is the CO2 corrosion rate at 300 degree c on carbon steel pipe?
Re: co2 corrosion rate
11/23/2010 10:21 PM
Really a lot.
11/24/2010 2:48 AM
as long as you don't have water condensation, dew point condensation, in my opinion you should not have corrosion.
S
corrosion prevention
Register to Reply 2 comments
