hi all
would you please help me on this!
i am installing automatic transfer switch controller which is controling the start and stop of the standby generator and transfer the load to the generator if the mains power failure.
the controller i fitted has no programable exercise time so the engine can run for some time and the battery is recharged, and what i am thinking is to fit battery charger controlled by timer rely and supplied from the mains power, so it will charge the battery of the genset from time to another.
on this ATS controller, when its on auto mode the mains power is present, there is one relay energized to keep the mains contactor on, so there is small load on the battery at all times.
my question is, what is the time should i program the timer of the charger so it will keep the battery voltage level, should it be ok if the chrging time is one hour per day? its 12vdc battery 90amps?
realy appreciate your advice
