Previous in Forum: Fan   Next in Forum: short circuit ratio(SCR)
NEED CURRENT BOOSTER MANUFACTURING COMPANY + CAPACITORS
11/26/2010 3:38 AM
Dear sirs
Kindly assist me on how to get
(1) Current Boosters
(2) Capacitors that can power an 1HP AC Electric Motor even when the source of current is disconnected for few 1 or 2 seconds.
Please help me with the website of the company, the address, or the telephone numbers or any other contacts that can help me with my research further.
My project is about generating electricity.
Thanks
Lawrence.
Re: NEED CURRENT BOOSTER MANUFACTURING COMPANY + CAPACITORS
11/30/2010 5:35 AM
I give you Doctorate in Electrical Engineering and recommend for Nobel prize in Engineering and science.
Good Answers: 804
12/01/2010 12:13 PM
No idea what a "current booster" would be. Current (Amperes) is a measure of use, not supply, although supply sources have a maximum current capacity that they can safely handle. So loads use current, therefore the only way to "boost" the current that a load uses is to increase the load. A supply system, i.e. a utility source delivered via transmission equipment, has a maximum current capacity that is in essence based on the thermal damage curve of the equipment. You cannot "boost" the capacity for that equipment to safely handle more current (short of maybe using cryogenics?).
Capacitors store a lot of energy potential, but not a lot of real useful energy, because they tend to discharge very quickly. So to be able to fully power a fan for 1-2 seconds with capacitors alone would be like using a massive rubber band to keep your car going up a hill at the same speed when the engine is shut off. It can be done, but you aren't going to like what it will take to do it.
Power Loss Ride Through for relatively large loads such as motors is the stuff of expensive backup energy sources, often called UPS systems (Uninterruptible Power Supply), of which there are electronics versions with batteries, and rotary ones that use large high inertia masses like flywheels to keep power on during outages. It may be less expensive to reconsider why a 1-2 second loss of air flow would be so critical in your system first.
