Previous in Forum: My Baby Hydro Generator Arrived Yesterday   Next in Forum: Rebuilding my 10' Dia, Circa 1871, Niles Boring Mill
Design
11/26/2010 12:42 PM
if water from showers and bathroom sinks go to a water tank. do you still need a trap? since there are no sewer gases involve?
Re: design
11/26/2010 1:26 PM
What makes you think there are no 'sewer gases' involved?
Sewer gas is caused (in this case) by the decomposition of organic household wastes. Potato peels, laundry detergent, the greasy stuff that comes out when you wash your hair... So, yes, you still need a trap. And a vent.
Will you credit CR4 for helping with your homework?
Good Answers: 179
Re: Design
11/28/2010 11:27 AM
Are you talking about the water supply lines located between the water storage tank(s) and the sinks & showers? If so, you don't need a trap on those supply lines because they'd be normally under pressure.
There should be no physical connection between the water supply lines (hot and cold water) and the drain lines! If there is a physical connection it is a code violation and a health risk. There is normally a vertically-oriented air gap between the two types of lines.
In regard to the drain lines, yes, there should always be a tap and vent stack located in the drain line to remove the sewer gases.
Check with your local building code enforcement officer/inspector and thoroughly familiarize yourself with the state building code and it's requirements and plumbing standards.
Uggghhh! I can't believe I answered this OP!
