Previous in Forum: Continuation Timeout (LF) in etap   Next in Forum: Serial Rapid IO Over Single Fiber
Why Can't We Directly Give D.C to Alternator Rotor?
11/26/2010 2:43 PM
Hi,
Normally in A.C generators we have brushless D.C excitation systems in which first of all d.c is given through external source to excitor stator,Then a.c is generated in exciter rotor which is rectified by rectifiers to d.c and then it is given to main alternator Rotor from which 3-phase a.c is produced which is taken out from stator,My question is why can't the d.c be directly given to main alternator rotor without any need of exciter at all,Thanks.
Sohan
Good Answers: 97
Re: Why can't we directly give D.C to alternator rotor?
11/26/2010 2:47 PM
You would need brushes, large ones.
CRTL-Z
11/26/2010 2:48 PM
Thats how it was done in the old days but you always had slip ring wear and brush wear to deal with. The method you are refering to is the brushless design which is primarily used to produce longer working life simple due to less wearable parts.
