Previous in Forum: Slow Broadband - The Unsuspected Culprit   Next in Forum: PAL 16v8
10 comments
Telephone and Communication Wiring for a Palace
11/27/2010 12:17 PM
I have been assigned a project for the wiring of a palace in which the owners palace has more than 50 telephone points and as many internet connections. He has about 40 intercom points too.
Then he has about 20 security cameras. More than 35 point each for satellite and terrestrial TV connection. Also there are a lot of audio points and alarms. His palace is just like a mini hotel.
I need to know the options that I have to manage all this ... how to go about this. The subcontractor has already done the conduiting and they have terminated at 40 cm by 40 junction boxes. So Pl let me know what paraphernalia is needed and how to complete it most economically. pabx,hubs ,switches with some example if possible.
thanks
Re: telephone and communication wiring for a palace
11/27/2010 12:27 PM
Palace? I'd think you'd need some local help to know what paraphernalia is needed and how to complete it most economically. pabx,hubs ,switches with some example if possible. It may cost you some money though.
Something this complex can't be done long distance, for free, with no information.
Hire an installer.
11/27/2010 12:51 PM
GA.... LL nice to see your barn it makes my holidays complete.
klearzen
11/27/2010 12:56 PM
Thanks,
We like it, too. About two weeks ago it got a new roof and the cupola refinished.
I won't get to see it till spring. The neighbors say it looks nice. Too cold for me there in the winter time.
11/27/2010 1:18 PM
good looking building.... copper cupola I suppose. Spring is only 4 months away. I for one, am looking forward to it. I will be finishing up my second set of electrical classes by then. Ray
klearzen
11/28/2010 4:24 AM
No copper cupola. Lutherans were into practicality, not show. Just painted steel. The second picture shows some of the wear inside, from milk cows I assume.
Good luck with the studies.
Good Answers: 97
11/27/2010 3:45 PM
It's not cold there yet and a striking contrast to the green frost has turned brownish but you've reminded me to contact "The Toothman"; thanks.
Re: Telephone and Communication Wiring for aPpalace
11/28/2010 1:17 AM
So you are faced with providing a solution to deliver voice, data, and video to various locations in the palace. I have been in the telecom industry for over 30 years and the methods for distribution and the technology supporting the aformentioned services has certainly changed over the years. The conduit infrastructure is in place and hopefully it was installed by someone that understands the need for smooth sweeps and not placed by an electrician that is used to installing 90 degree turns. Also should have pull strings in place hopefully to allow you to place the cable(s) needed for the install. For pure data distibution you could run cat 5 or cat 6 ethernet cable which would easily handle up to 100mbps. With a large facility you could identify logical hubbing points to distribute from. This would help ensure better quality and also help you manage the faciltity and equipment. You might also need to consider secure wifi halo's in strategic locations?
For voice you could go "old-school" and run a network of copper pairs for traditional analog telephone service and provide some form of switching via a mini pbx. It would be much easier to consider a VoIP solution though, and utilize your data infrastructure and hubbed switching network. You could use a variety of VoIP phones on the market, and if you needed to use an analog phone for a certain location you could employ the use of an ATA (analog teminal adapter) which would convert the standard phone for use over a data\VoiP network. If you can find a local service provider that has a VoIP switch and provides business class VoIP services they may be able to set this kind of local VoIP network up and provide a virtual VoIP PBX service with custom inbound and outbound calling options, station-to-station calling and call groups, and of course LD, and local services with class service features like call waiting, cnam, etc... . Lots of things to consider and one major factor is "who will provide the underlying services for you?" Its certainly easier if you can get a qualified provider to help provide a composite of all of the services you need, otherwise alacarte solutions from various providers are certainly viable but harder to manage from a service and maintenance perspective. Get SLA's (service level agreement) from your service provider(s) to ensure you have some form of reference regarding a formal agreement of service quality and their commitment to responding to your service needs.
Just a note on security. The security system should probably be segregated in some fashion to ensure qos is maintained and intrusion prevention is controlled. You will also need to consider how you will manage your internet drain connection to your provider and which kind of routers, firewalls, and other security management tools you will need. I recently worked for an organization that sells a security appliance that can filter ingress\egress via Ip, country code, etc. It actually sets in front of your firewall. At any rate this is always an area to keep in mind depending on the need for network security. If this location is really huge, perhaps you should consider setting up a small secure data room facility with power and HVAC back-up. This data center would also give you direct access to the router management and security monitoring displays. Even the method of providing electricity and outside world cable facilities might benefit from redundant point of entry. This all might sound like overkill, but I have worked with a lot of disaster recovery initiatives and real-life experiences over the years and its something to consider at the very least.
The video could be high quality coaxial cable or fiber and the system might be RF\digital or could even potentially be an IPTV solution. Again it really depends on your providers and the services they support. The jack interfaces in the rooms can be modular with the ability to allow you feed various types of interconnection out of one startegically placed jack (if that makes sense). Streaming video solutions via the internet can be connected directly via your data network and provide an overlay to a standard RF or IPTV solution and in some cases may end-up being the primary feed for video depending on the viewers video choices.
At the end of the day my suggestion to you is to retain someone that can help you sort through the various options and help you create a sound project plan for designing, installing, commissioning, and implementing the services you need. I have just scratched the surface to provide a little information and the details can really get complicated. Dont underestimate the need for proper planning and expertise on this or you will end-up wearing the results.
Good luck with your efforts and I hope this information helps a little bit.
Re: Telephone and Communication Wiring for a Palace
11/29/2010 3:47 PM
I agree with the others... there are many, many things to consider.
Things not mentioned: Building management (including yard watering and rain detection, exterior and interior security lights, vehicle detection) Ancillary buildings and grounds monitor and management, Intruder detection, Fire detection and annunciation, Access control and access automation... just to list the first few that come to mind.
"The subcontractor has already done the conduiting..." What plan was he following?
"...complete it most economically." I admit, I am curious: Just what is cost effective about maintaining any portion of an 'I live in a palace' lifestyle?
11/29/2010 9:04 PM
Might start with Cisco, who is integrating voice, data and video with their gear. Other smart router makers use T1 or T3 to interconnect a network of routers, and most any type of input can connect to a router and travel the network, and also connect to the Internet. I think you definitely need someone who does this stuff for a living, and should specify a turnkey project, where they do the work and you manage.
11/30/2010 2:26 AM
Thanks for the interest shown. .Let me clarify a few things. This palace is being built for a Sheikh in Middle East. It's not truly a palace of the sorts shown in movies; still it's a trend here in Middle East to call the residences of sheiks as palaces. But still it's a big compound with fairly good facilities.
My scope of work would be to manage interconnection of various telephones, intercoms, internet points, TV points, audio music/Koran prayer and CCTV cameras. It doesn't have any sensors as used in smart homes and no intruder alarms. Just monitoring it on TV. That's all. No vehicle sensor, no access control no automatic doors etc. He has a lift inside though so there might be a need for telephone connection to that.
Overall it's not that complicated but the only thing is it has a lot of outlets for each service so I want to know practically what equipment is available in today's date to handle all this so that I can quote the best price and check its availability in middle east. With technology I think we can club all these services in one panel itself, rather than going for an individual panel.
I am looking for a positive reply which would aid buying the best model available in the market, I can import it too if it's not readily available... just need to know the options from you experienced engineers.
Thanks again.
Register to Reply 10 comments
bwire (1); Doorman (1); klearzen (2); lyn (3); N10S (1); SSCpal (1); v1406 (1)
