Previous in Forum: Instrument Tech's   Next in Forum: Flow Meter Insertion Type
Steam Turbine Bypass System
11/28/2010 8:30 PM
Good day everyone... in a coal fired power plant which employed a reheat steam turbine associated to it is a turbine bypass system. my questions are, 1. what is the function of the High Pressure Bypass Valve? if it is controlling the pressure of the main steam inlet for HP blades, how it does? 2. same question to number 1 but it refers to Low Pressure Bypass valve from Reheated Steam bypassing to IP/LP blades of the turbine directly to condenser? Basically, my query is all about the function of Turbine Bypass System. Thanks ahead..
Re: Steam Turbine Bypass System
12/06/2010 9:04 AM
Hi
1-During boiler start-up:
.To assure the required minimum flow through the reheater
.Gradual reheat steam pressure increase during boiler start-up
.To limit a reheat steam pressure drop
2-To dump steam not accepted by the steam turbine (load rejection,ST shut down)from HP main steam system into the condenser
Reply to Forum Thread
