Previous in Forum: Manual Generator Synchronization   Next in Forum: Relay Protection
Different Between Bus Riser and Bus Coupler?
11/30/2010 11:50 PM
what is the different between bus riser and bus coupler?
Re: what is the different between bus riser and bus coupler?
12/01/2010 12:06 AM
Just look at the Switch board /schamitic drawings. You will understand it better.
12/01/2010 4:56 AM
Buscoupler connects two bus sections which being fed from two different Incomers,like Incomer-1 ---- Buscoupler -----Incomer-2
Busriser means When your outgoings or Incomers are busbars rather than cables,and it runs through an enclosed Busduct upto the destination.
There are no shortcuts on the road to a great experience.
12/01/2010 5:50 AM
Bus-coupler is a coupler breakers that installed between the Incomer-1 and Incomer-2 that connects two bus sections which being fed from two different Incomers or transformers.
Bus riser is a set of bus bar that connected from the coupler breakers, outgoing section enclose in the panel and connected to your incoming 1 or incoming 2 bus bar section. It depend which side is your outgoing from the bus bar coupler breakers or depend on your electrical design.
12/01/2010 6:21 AM
Yeah Wan is right...I took that in another way
Register to Reply 4 comments
Anonymous Poster (1); Aseer (2); Simon Wan (1)
