Previous in Forum: Why has not auto world looked at digital technology?   Next in Forum: Drive Train or Power Train
1999 SAAB 9-5: No Heat in Front Passenger Zone/Area
12/03/2010 6:31 AM
The situation with my 1999 SAAB 9-5 is that the front passenger zone has no heat. The fans/blowers work, but there is no heat. The driver and both rear passenger zones heat up beautifully. Any help would be most welcome. Many thanks.
Re: 1999 SAAB 9-5: No Heat in Front Passenger Zone/Area
12/03/2010 8:40 AM
12/04/2010 7:53 PM
Many thanks for your help. Will give it a try.
Regards
Good Answers: 179
12/04/2010 11:01 AM
Check for the correct operation of the "vane" inside the heater box....you may have to remove it from under your dash.....most likely an easy fix once you get it out....but a real bear trying to get it out from under your dashboard (I'm not familar with SAABs inner workings).
Good luck!
12/04/2010 7:55 PM
Many thanks for your help. Once I get the dash off, I'll have a better picture of what's going on .... or not.
Many thanks.
Regards
Register to Reply 4 comments
CaptMoosie (1); IkeOesq (2); kramarat (1)
