Previous in Forum: How Do I Re-plate Plastic Dial Knobs?   Next in Forum: Helium Required to Lift Given Payload?
Fuel Oil Resistant Adhesives
12/05/2010 11:30 PM
Hi everybody,
I am looking for an adhesives which are RESISTANT TO FUEL OILS.
Application: This adhesive is used to rubber line the inner surface of a shell. Shell's interior surface would be liner with Nitrile rubber and this adhesive is used in between the rubber and shell to stick it.
Can anybody suggest the adhesives which are RESISTANT TO FUEL OILS?
One has to watch out for engineers - they begin with the sewing machine and end up with the atomic bomb. - Marcel Pagnol
Re: FUEL OIL RESISTANT ADHESIVES
12/05/2010 11:44 PM
Polysulfide rubber(sometimes referred to as Thiokol) is fuel resistant. it was used to seal the fuel tanks on the SR-71 Blackbird. It is also used as a tooling compound.
Check it out.
