This question is for someone with sound knowledge about centerless grinding and geometry. The item in question is a shaft 157" long with a 3.75" diameter with a diameter tolerance of ±.001". The shaft has a rockwell C hardness in the mid 30's.
There is also a call out on the diameter to be within .ooo5" run-out per foot, .005 per 10'. Question: is this a valid call-out, i.e. how could the run-out accumulate with a ±.001" tolerance on the OD? Second question: Could one assume if a centerless grinder held the OD tolerance could one say the straightness of the shaft was also within the tolerance of the OD, .002"?
