Previous in Forum: Earthing of project   Next in Forum: Electric Shock in a running train
13 comments
MAZDA RX-8 2005
12/15/2010 7:51 AM
good morning guys
my Mazda rx-8 2005 power steering fail and a light came on in the dash with an excalmation sign, but the power steering has no pump its electronic, anyone who knows why I should do to fix it??? I can drive the car but its TO HARD to drive because the power steering its not working?????
Thanks
Dave - Puerto Rico
Re: MAZDA RX-8 2005
12/15/2010 10:02 AM
Start by checking your fuses.
excalmation sign usualy means your hand brake is on
12/15/2010 11:43 PM
Re: the usualy means your hand brake is on
12/16/2010 4:50 AM
Not on my car - it actually says brake- the excalmation point is used for everything else and it could be red or amber - depending on the severity of the problem
Re: MAZDA RX-8 2005
12/16/2010 6:32 AM
Power steering read (elecricaly assisted) fuses yes as pre mentioned if that wont cure it .. try alldata...or..My RX8 had the same problem. First, check your battery cable ends. On the Positive cable there is a white wire that powers the power steering. It probably has a bad connection at the battery post. I cut the end off mine and just put a regular battery cable end on it and my problem was solved.
Torque is not cheap
Re: MAZDA RX-8 2005
12/16/2010 7:07 AM
A recall on certain 2007-2009 Mazdas has been made via the NHTSA (National Highway Transportation Safety Administration), concerning power steering failure. You might want to visit the web site to see if earlier years of your model has been reported or included recently.
Re: MAZDA RX-8 2005
12/16/2010 5:22 PM
Im already check the fuses and the battery cables and the problem didnt fix it!!, thet day that the car wont start a guy Jump it my car with his car, do you think that maybe this cause the problem?? a mechanic told me that if i scan the car and reset the computer using the scanner maybe fix the problem!! what you guys think about that=???????
thank you
Dave
Good Answers: 97
Re: MAZDA RX-8 2005
12/16/2010 8:23 PM
Disconnect the battery cables for at least 8 hrs and the capacitor within will deplete clearing the ECM.
Re: MAZDA RX-8 2005
12/17/2010 8:07 AM
hey i found the white cable and at the end of the cable i found a relay that is broken im goint to replaced the relay then lets see what happend
Good Answers: 123
Re: MAZDA RX-8 2005
12/17/2010 9:34 AM
Dave, is that you? Are you answering yourself. Is it multiple personalities? If you log in as guest, just sign your name on the bottom. It will eliminate a lot of confusion.
Bob
Re: MAZDA RX-8 2005
12/17/2010 9:05 AM
check your conection , the wire i
f it got voltage there ?
Re: MAZDA RX-8 2005
12/17/2010 10:44 AM
yes bob its me dave, excuse me im on my cell phone, im login at home, thank you bob
Re: MAZDA RX-8 2005
12/17/2010 3:51 PM
hey Guys!! Fix it!!!!!!!!!!!!!!, it was the relay at the white cable!! thank you !!!!
now i have my power steering working again!!! thank you!!!
Dave
Good Answers: 123
Re: MAZDA RX-8 2005
12/17/2010 8:12 PM
Thanks for posting, and letting us know. ( I hate loosing sleep worrying about this type of thing)
Bob
Register to Reply 13 comments
Anonymous Poster (6); bob c (2); bwire (1); dervech (2); kramarat (1); merc600sec (1)
