Hi Could somebody please explain the reason for the use of Star & Delta connections in Transformer metering application, What is the reason? Is there any diagrams available to explain the application.?
I have a situation where the Protection CT's second winding - The metering wirnding (Cl1) 1S1 & 1S2 are wired to a "DELTA" configuration group of CT's, from there is't going to a control system and then back to a PLC input. The problem is that the Control system's Current display differs significantly form the PLC current display, two thirds less than the control system display. I suspect that there is a wiring problem after the control system towards the PLC input. Any thoughts on this one
