Looking for a good conversation point at the water cooler today. I have an issue with a spray gun used to apply a 2k oil based coating to a substrate here.
Info on gun
The guns nozzle is 1.0 MM with a 1.5 MM air cap. Paint pressure coming to gun is 2 - 5 psi.
Operation is as follows, Substrate is moving under guns at a rate of 100 FPM on a continuous basis. Meaning once the guns fire they will stay on for many thousand's of feet. They are not cycled once spray application is started. There in lies the issue. Most applications are done with the guns cycled on and off. This helps to keep the nozzles clear just by the action of needle moving in and out of nozzle. We can not do this with this substrate.
Any thoughts out there or has anyone worked this out yet with other processes.
