Previous in Forum: Manual Building Construction Estimating Guide   Next in Forum: Polaris' Changing Declination at Upper Culmination
Design Parameters for Solar Evaporation Pond
12/23/2010 4:45 AM
Suggest me for standard parameters for the design of solar evaporation pond
Re: Design Parameters for Solar Evaporation Pond
12/23/2010 7:10 AM
Be sure to put it in a sunny place.
Good Answers: 140
12/23/2010 10:55 AM
Standard Parameters you say...
1) A hole in the ground.
2) A liner of some sort.
3) The liquid you wish to evaporate.
4) and... Sunlight.
Given the lack of any meaningful data in the question you posed, how could anyone give you any type of real answer.
Here is a link that may be of some assistance.
http://en.wikipedia.org/wiki/Interactive_communication
12/23/2010 11:19 AM
So as not to confuse Guest, in case this Guest is the same Guest that posted this:Soakway thread.
The general parameters of soakways and solar evaporation ponds are similar. You can convert a soakway to a solar evaporation pond with the addition of 2) above. (A liner of some sort)
However, soakways tend to be deeper and smaller in diameter than solar ponds, and may be less efficient if converted.
I recommend "Soakways and Solar Ponds, the Myths and Mysteries Revealed" published by LynDoor™ Press.
