Previous in Forum: ASME External Pressure Question   Next in Forum: What is Surface Heat Pumping Related to Pulse Tube Cryocooler?
Different Between Gas Turbine and Microturbine
12/23/2010 5:36 AM
Dear All, What is the different between gas engine and micro turbine system operation and process. Regards
We Stare Because We Care
Good Answers: 101
Re: Different Between Gas Turbine and Microturbine
12/23/2010 11:28 PM
Gas turbines work on gas while micro turbines are micro.
