This is about the accretion of zinc ions on electrodes in biological systems. Proof of concept in biological systems is provided by Joseph Wang's work using a carbon fiber electrode sensor to measure zinc levels in vivo.
Please consider the following experimental conditions and post your reasoning about the expected results re: zinc accumulation on implanted electrodes.
Let us suppose that all of the experimental animals are implanted with several wireless neurostimulator prototypes made from different conductive materials: platinum, iridium, polyimide and PEDOT. The devices are designed to receive stimulus pulse trains from an external transmitter or linear amplifier in the cage.
The animals are then divided into two groups, one of which is given an ordinary zinc supplement, and the second group is given a chelated zinc supplement.
Animals from both groups are allocated to the following treatments:
(1) stimulus at the usual levels for therapeutic treatments (low level pulsed stimulus)
(2) stimulus at levels that produce gross motor dyscontrol, severe choking or gastrointestinal symptoms, and other major side effects (high level pulsed stimulus)
(3) no stimulus (control)
On the assumption that zinc from the supplements will be attracted to electrically active electrodes:
- Which electrode material will attract and accumulate the most zinc and why? Feel free to discuss other materials than those named.
- which level of stimulus signal will attract and accumulate the most zinc? (Ok, can you confirm in principle that higher levels of stimulus signal will attract more metal)
- what differences, if any, are expected in experimental groups with ordinary zinc vs chelated zinc supplements?
Last question, assuming that the stimulus signal is completely programmable, what change of parameters would be expected to release the zinc accumulations from the electrodes.
