Previous in Forum: MCC Panel Shop Drawing   Next in Forum: Maximum Demand Controller
9 comments
Electrical Engineer
12/28/2010 2:38 PM
I am planning to use 27/59 (GE IAV53K) relay for main transformer protection during backfeed operation when main generator links are removed. The Transformer is Delta-Y Grd. The relay will be connected thru CTs on Delta (Low Voltage) side. The Cts are Grd Y-Grd Y
Can you explain, what happens to voltages and currents on Delta side when one of the Y side (345kV) lines faults to ground. How this one single phase relay could provide indication of over volatge as well as under voltage conditions?
Thanks.
CR4 Admin - email address removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
Pathfinder Tags: Relay 27/59
Re: electrical engineer
12/28/2010 2:45 PM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
12/28/2010 2:50 PM
Irrelevant This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
12/28/2010 3:45 PM
CR4 Admin has been busy on this thread.
"...and would otherwise be taken out of context." Hmmm. This being the case, it is a wonder Admin lets me say anything at all.
12/28/2010 3:58 PM
At least I didn't have to go sit on the naughty step for my comments. I'm gettin' better.
Good Answers: 181
12/28/2010 6:46 PM
True, but you're now classified as irrelevant
12/28/2010 6:50 PM
Not just irrelevant, but "Irrelevant"!!!!!!!!!
After all I've done for them!
Re: Electrical Engineer
12/29/2010 12:39 AM
Due to fault in one phase voltage in other phases will be changed which will be sensed by the 59 relay.
BNDas
Good Answers: 116
12/29/2010 5:03 AM
Surely you mean connecting relay to VT/PT (Voltage/Potential Transformers), not CT (current transformers)!! By convention, the high voltage side of a transformer is written first e.g. 11/0.4 kV, writing Y grd - delta would have been better. If you had put IAV53K into a Google search you would have got to http://www.gedigitalenergy.com/products/manuals/iav/geh1814.pdf, which is the manual for the relay, which will show how it does under and over voltage in one box.
12/29/2010 10:54 AM
It was good answer but CR4 ADMIN deleted my post.
Register to Reply 9 comments
67model (1); Anonymous Poster (1); biswanath.das (1); Doorman (1); lisa123636 (1); lyn (3); TonyS (1)
