I forgot my password.
Don't have an account?
I NEED TIME CYCLE BECOME 7 SEC, TORQUE=332.044.HOW I WANT TO GET A CORRECT STROKE & BORE FOR THAT CYLINDER
1- are you aware of the way you wrote your message ? From a technical point of view it is totally nonsense.
2- a cylinder can only supply a FORCE
3- a number has no value is units are not also written near by
4- I doubt that you even understood the technical aspect of the problem
I think it is a home work and CR4 do not make home works only helps if a student is in difficulty.
Last but not least, do not shout avoid the use of capital letters if not needed.
In fact the answer to the way you formulated the text is : by correct computing ! Satisfied ?
