Previous in Forum: Differential Gear Ratios for 4WD and AWD Vehicles   Next in Forum: Need Little Wheels
Ford Festive Head Temp
01/08/2011 11:03 AM
What is the operating range of this 4 cyclinder engine?
Re: ford festive head temp
01/08/2011 11:18 AM
Sigh.
The operating temperature inside the combustion chamber will vary wildly. The operating temperature of the exhaust manifold will be very hot. When the intake manifold has a vacuum, the operating temperature will be slightly below most of the engine parts. The operating temperature of the alternator will be above ambient temperatures. The coolant temperature in the block will rise until reaching the melting point of the wax in the thermostat. Then the radiator cooling will attempt to keep this fluid at not much more than this temperature.
Good Answers: 60
Re: Ford Festive Head Temp
01/08/2011 4:58 PM
Carefull you dont give us too much information, You might wear out the Keyboard
Good Answers: 97
01/08/2011 5:10 PM
The temporate zones surely
01/08/2011 5:38 PM
You need a 180° F thermostat, that's probably all you need to worry about.
Good Answers: 97
01/08/2011 9:59 PM
Hi Farmer steve this is a very good engine an a thermostat 180° - 190° is what is needed to allow the emissions equipment to fuction properly and you'll gain fuel economy too.
Register to Reply 6 comments
bwire (2); kramarat (1); peterg7lyq (2); redfred (1)
You might be interested in: Captive Screws, Nails, Lockbolts
