Previous in Forum: Pneumatic Lift   Next in Forum: Mesh For Sea Water Suction Line
Conveying Elbow Pipes
01/10/2011 8:48 PM
Dear sir,
I would like to get your advice on conveying elbow pipes ranging from dia 8" to 30" and joint pipe length is max 12m. I would like to convey them in automatic system along its fabrication process. Upon my basis understanding, the elbow pipe cannot be conveyed by a conveyer. Is it right? Kindly let me get your advice how they should be moved with less manual work.
Thanks,
Kotuu2.
Re: Conveying Elbow Pipes
01/10/2011 9:26 PM
Conveyors are not my field, but I have visited factories where motor cars and light trucks are moved using conveyors. I am sure that someone could design you a chain driven conveyor with "buckets" to cary your pipe elbows. (Or even an overhead chain with hooks to support the pieces in front of operators.)
Your challenge will be trying to automate any other portion of the process.
Good Answers: 21
01/11/2011 6:50 AM
Depends on what your going to do to them as they are moved along the conveyor. If your needing to machine them, then a pallet fixture and chain systems will need to be developed. If all you want to do is move from point A to B then a good troughing belt conveyor would do. As you see there is not enough information in your request for help to help you much.
Good Answers: 266
01/11/2011 7:41 AM
Yes they can be conveyed on a live roller conveyor. With out a better idea of the process involve it is difficult to give advice. They maybe better conveyed slung on an over head conveyor. As on tramrail. As that would be a great reduction in floor space over a conventional type conveyor.
01/11/2011 10:23 AM
Dear all,
Do thank for your all kind advice. Pls let me add in more info here.
I am now trying to help in movement of elbow pipes along pipe fabrication line. The problem is the space is very limited in width (approximately 1.5m). Raw pipes and elbows will be moved along 60-m workshop length since all welding sections are set in workshop's length.
My thinking is that it may be helpful to my workers if a mechanized movement system is installed. It may become less job, less effort and more safety for them.
If I use a roller type conveyer, straight pipe movement is fine but not for elbows.
Should I use a trailer with a tracking system?
Thanks again,
Kotuu2.
Note : Pipe dia range is 8" to 30" and max length is 12-m after joined.
01/12/2011 12:35 AM
If you have one welding booth, think of over head crane attached with special magnetic clamp.
01/12/2011 11:34 PM
http://www.exair.com/en-US/Primary%20Navigation/Products/Air%20Operated%20Conveyors/Pages/Heavy%20Duty%20Line%20Vac.aspx
ramaraj@mpowerautomation.in
Good Answers: 181
01/13/2011 12:31 AM
How are you going to get a 30" pipe elbows through a vacuum cleaner?
Enter the Monty Python team Vikings.
Spam spam spam spam spam spam spam
Lovely spam lovely spam
I like spam, I'm going to have:
Spam eggs spam beans spam spam spam and spam
Shadup! Bloody Vikings
Register to Reply 7 comments
Anonymous Poster (1); fixitorelse (1); Just an Engineer (1); KOTUU2 (1); ozzb (1); TonyS (1); user-deleted-1100 (1)
