Previous in Forum: How to Convert this Problem into an Opportunity?   Next in Forum: Pressure Ratings- CS vs SS
Leaf Spring into Machete
01/13/2011 5:46 PM
I have an old leaf spring that I would like to make into a machete.I know I will have to heat and straighten it,that is no problem,,I have the equipment,the problem is the proper heat treating and welding/brazing after straightening.I presume the spring steel is high carbon steel, so welding would be unreliable,so I will drill and rivet the handle hardware.
Can someone give me the proper heat treating procedure to give a hard but tough blade that will hold a good edge?
Thanks.
Re: Leaf Spring into machete
01/13/2011 5:55 PM
Here's a good reference. Go by color, just like the good ole days.
http://www.threeplanes.net/toolsteel.html
Re: Leaf Spring into Machete
01/13/2011 7:59 PM
Save yourself a lot of work. LynDoor™ is out of stock, so we show you the next best source for free.
