dear all hope that all of you would be fine and enjoying life yesterday i was installing an inverter which behaved very unusual i was unable to configure the fault so thought that i would be better to post something to get the comments and ideas of various genius people around the world
actually the rating of the inverter was 4 Kw and its make was schneider electric France when the inverter starts you have to set the operating frequency which i set 50 Hz which is nominal here now when i gave a start signal to the inverter it starts ramping up and after reaching the frequency of 28, 30 Hz it gets tripped mean to say the motor connected at the out stops. now i installed another inverter of the same kind and matched it settings with the one previously installed the next one is working just fine.
now there is also an option in the inverter to set the HSP and the LSP mean to high speed and low speed i simply set the HSP to almost about 25 and then started the inverter again now the inverter was working fine
my problem is that why the hell is the inverter not working on 50 Hz when all of its settings are configured as default if any one of you have any ideas plz comment waiting for ur replys
