Previous in Forum: Why Starting and Running Torque of DC Motor > Than AC?   Next in Forum: Use of Resistors?
Calculate Electric Field Generated by Charge
01/14/2011 6:37 AM
I have an elctrical charge in the air and below it I have a container filled with water. How do I calculate the electric field generated by the charge on the bottom of the container? Bear in mind the electrostatic constant in water is different than from air.
Re: QUESTION
01/14/2011 6:41 AM
Peeyo..peekay calculate karo
Re: Calculate Electric Field Generated by Charge
01/14/2011 8:14 AM
What is the conductivity of the water? What is the altitude? What is the relative humidity? Is the "electrical charge in the air" + or - ? What color are your socks?
Good Answers: 181
01/14/2011 8:29 AM
Do you any of your own homework?
01/14/2011 8:44 AM
How about learning electrostatics?
Good Answers: 29
01/14/2011 8:48 AM
It's Friday morning where I am. Maybe that explains it.
Good Answers: 119
01/14/2011 11:35 AM
Study and learn Electrostatics and the underlying math required. These are some of the important basic building blocks needed for the science and engineering fields.
Register to Reply 6 comments
Anonymous Poster (2); lyn (1); mjb1962853 (1); RDGRNR (1); TonyS (1)
