Previous in Forum: IEC NEC BS Breaker Overload Fuses for Motors   Next in Forum: Coronal Mass Ejection Effect on PV Solar System
9 comments
Type Tests
01/19/2011 9:22 AM
Is it required all the type tests to be carried out in same Switch gear( MV and LV switchgears) as per IEC/BSEN standards? For example, few type tests are done on Switchgear #A and other tests on Switchgear B. But the Panels for the Project are manufactured as per the same configuration of A and B. Is that normal procedure in switchgear industry?...
Good Answers: 131
Re: Type Tests
01/19/2011 12:29 PM
That's what type test means - Testing is done on one unit which represents the common design for a "type" of equipment, and the results are valid for all the units of that "type." Thus the use of the word "typical" to mean valid for all of a certain type.
Re: Type Tests
01/19/2011 10:05 PM
Thanks. I will register and give GA.
India - Member - New Member
Good Answers: 164
Re: Type Tests
01/19/2011 11:17 PM
If you mean whether all type tests are to be carried out on the SAME sample, the answer is no. For example, a LV circuit breaker needs to be tested as per IEC 60947-1&2, where at least 4 test sequences are to be followed to certify the Circuit Breaker. Normally 4 to 6 samples undergo different tests.
Re: Type Tests
01/20/2011 6:32 AM
Ok. I understand. Where can I find the supporting documents including the standards as like clause no etc?..Just give me a hint. I will find out. I have to support supplier to fight with consultant
Good Answers: 164
Re: Type Tests
01/20/2011 6:50 AM
i already gave - IEC 60947- part 1 and 2 for Circuit Breakers. If you are in India, you can use IS 13947 - 1 and 2 which are identical and far cheaper. You can also ask CPRI and ERDA, who are testing authorities in India.
One advice - never fight with a consultant. He can always throw a spanner in the works.
Good Answers: 170
Re: Type Tests
01/20/2011 7:43 AM
KVS, I think IS 13947 is renamed (or is it re-numbered) as IS 60947, to be in line with IEC. Pl. confirm. I very recently received a mail from my seniors in this regard.
Re: Type Tests
01/21/2011 11:58 PM
As per your suggestion, I read the following standards in the last three days.
1.IEC 60947-part 1 LV switchgear - geberal
2.IEC 60947-part 2 - Circuitreakers.
3.IEC 60694-Highvoltage switchgear and control
and the below mentioned Type Test standards
4. IEC 61436 part 1 to 7 for LV switchboards, Busbars.etc
5. IEC 60227-200 for MV switchgear.
I could not find (or understand) anywhere it said that multiple samples are required mandatory for type testing.
Sir, could you give me more clarification on this reagrds.
Good Answers: 164
Re: Type Tests
01/22/2011 12:43 AM
i give a small extract of Table X of IS 13947-2. You will notice that tests are specified on sample 1, sample 2 etc. This is a small part of the table, you will get more data from the IEC.
Re: Type Tests
01/22/2011 3:59 AM
Thank you. I saw almost similar to this in IEC.
Anonymous Poster (4); electricalexpert65 (1); kvsridhar (3); PeterT (1)
