Previous in Forum: Fatally Flawed   Next in Forum: Methane Ingerter
Capacitior Issues
01/19/2011 11:14 AM
We manufacture geothermal swimming pool heating equipment as well as air source heat pumps for pools.
We are experiencing a high rate of failure on compressor run capacitors, specifically an 80 uf / 440vac version. We have tried several vendors and run into the same issue regardless of brand.
Is anyone else experiencing a similar problem with todays capacitors?
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: Capacitor Issues
01/19/2011 6:08 PM
When I read what you wrote about using different brands and having the same problem, the first question I asked was, "What is the common thread?"
I'd venture a guess the problem doesn't have to do with a deteriorating quality of electronic parts from all manufacturers, but something more simple. If you put various brands of light bulbs in a socket and they all blow continually, do you suspect a problem with all light bulbs or the socket (or the power supply, etc)?
Based on the fact you've used different brands, the blown cap seems like a symptom of another problem to me.
Sometimes my thoughts are in a degree of order so high even I don't get it...
01/19/2011 8:52 PM
Well, the schematic is fairly simple and we have been doing this for 30 years. The capacitance and vac is set by the compressor manufacturer, Copeland, and we have asked for and received verification of their specifications, so we're certain that the application is correct.
Good Answers: 58
Re: Capacitior Issues
01/20/2011 9:08 PM
This is a good forum for electronic problems, especially capacitors.
mike k
Register to Reply 3 comments
ChaoticIntellect (1); jatawney (1); mike k (1)
