I have made some cir. for 3 watt leds and worked out well. I thinking of buying some 20 watt leds ,voltage is 13 to 18 input. amps are about 2. Could I hook these directly to a 12 auto battary? or would I have to put a resistor in the + side for control of the current.A auto battary will go to I think about 15 volts. Also I was going to put in a regular chip to make it only go to 12 vdc.
I had on 20 watt led and it said input voltage was 12/15 I think, but when I hooked it up to a car battary it worked and Bright for awhile and then went about 1/4 dim , I think because it got over heated.
Tks
John B
