Previous in Forum: 2400W Generator Fails to Start Shop Floor Tools   Next in Forum: Difference B/W using a Contactor and Circuit Breaker for A H.T Motor?
11 comments
Cummings Genset With Stamford Generator
01/27/2011 3:48 PM
I have a 3ph, 50 hz cummings gen set with a Stamford alternator, which is KVA133.75 Could someone please tell me where I can find a wiring diagram for the Stamford generator. It is a used Genset brought out of the UK some years ago but was never commissioned, which is what I want to do now. Any assistance, greatly appreciated. Thanks
Re: Cummings Genset With Stamford Generator
01/27/2011 4:01 PM
Have you taken the obvious first step and searched for it on-line? With the manufacturer?
It might save the forum some time if it knew what you have, or have not, done.
01/27/2011 7:40 PM
Yes I have looked online, but could not find it
Good Answers: 58
01/27/2011 4:16 PM
"KVA133.75 Stamford alternator" - This is good info to start with!
Now how about some info off the alternator such as:
Year Built ?
Model Number ?
Serial Number ?
Hopefully there is info either stamped on a metal tag "name plate" or stamped directly on the alternator.
Good Answers: 116
01/28/2011 8:50 AM
And rated voltage, current , power factor?? British Standard? All rating plate data is useful.
01/28/2011 1:59 PM
The Metal Plate details are as follows: Stamford Alternator to B.S.S 2613 No.: 84836 / 2 Type: 645 P.F. 0.8 Vol: 415/240 KVA 133.75 PRM 1500 Amps 186 Charging volts Excitation volts 23 Rotor Insulation F Stator Insulation E Rating Cont Hz 50 Phase 3 This is all the info I can find. Thanks for the feedback so far.
Good Answers: 116
01/28/2011 6:43 PM
Stamford were swallowed by Newage, who were swallowed by Cummins. Cummins site gives Cummins Generator Technologies) it lists Stamford & Markon on start page:-
http://www.cumminsgeneratortechnologies.com
01/28/2011 2:06 PM
No other info is available, save what I have now posted. but from the Cummings Engine I found the following: Model : 424B24E/H Serial No.: 26978 RPM 3300 Ring BM 93520 Piston: 185310 Engine No.: F0350 32 Thanks
01/31/2011 8:22 AM
Its prety easy, Open the terminal box, AVR box(separately mounted). Check the wiring. If you have a basic idea of Brushless generator of someother make, you could fix it... ok,
best of luck!!
BNDas
09/10/2019 3:37 PM
Hi.
Just both the same Generator b.s.s 2613. 80.0kva
have not pict it up yet.
it have been just as a emergency generator at the ife in norway. so it have maby 50-150 hours of runing time. and service every year most likely. but for the last fue years maby 10 years it have been stored in a garage and never been started.
can you tel me have your rebuilding went. do you have any advice? link? information.
Greets Vegard.
09/10/2019 4:19 PM
09/10/2019 5:18 PM
Thank you
Register to Reply 11 comments
67model (2); biswanath.das (1); Guysons (3); KJK/USA (1); lyn (1); SolarEagle (1); Vegard Norway (2)
