Previous in Forum: Faulty Bearings - Consequences of Not Replacing Them?   Next in Forum: Calculating Force (Rear-End Auto Collision)
2001 Saturn SC1 Transmission Issue
01/28/2011 10:42 AM
My daughter has a 2001 Saturn SC1 with 100k+ miles that has recently developed an issue I believe is transmission related. When the car shifts gears (up or down) it makes a loud "kerchunk" sound, accompanied by the car shuttering as if it's driven over a large pothole. It almost feels as if the transmission is ready to fall off the car. She was a little low on transmission fluid, which we topped off, but it didn't help. This problem seemed to appear overnight. Any suggestions??? Thanks.
Re: 2001 Saturn SC1 Transmission Issue
01/28/2011 1:26 PM
my daughter had the same model saturn with an almost identical problem. it was one of the top engine mounts had become slack, check all engine mounts and replace as needed.
01/28/2011 3:45 PM
Wow, thank you! I'll give that a try...
Register to Reply 2 comments
You might be interested in: Metric Gears, Bevel and Miter Gears, Gears
