Previous in Forum: Flow - How to Calculate   Next in Forum: Calculate Flow
What Transmitter To Use-Acid Tank Level .
01/28/2011 12:20 PM
From many days I am facing a problem . Regarding what type of transmitter to be use for acid tank level at DM Plant of my power plant. Presently what I am using already got damage in contact with acid. The supplier told no to use the TX for that purpose. What should I do.
"MAKE CHANGES BEFORE THEY ARE FORCED UPON YOU." "PROBLEMS ARE SIMPLY CHALLENGES WAITING FOR SOLUTIONS TO MEET THEM"
Re: What transmitter to use-Acid tank level .
01/28/2011 6:29 PM
Use the TX that the supplier tells you to use. Apparently, you are not competent to select your own.
Or, do some independent research into chemical compatibility of materials used in the construction and learn to make your own decisions.
What would you do if we were all asleep and you needed an answer?
Re: What Transmitter To Use-Acid Tank Level .
01/29/2011 12:07 PM
try to use Krohne Radar levelsensors, ask them about compatibility with the type of acid you use in the power plant. they are used in a phosphoric acid plant I worked in and they work very well in rough conditions.
masteryoda
01/30/2011 2:09 AM
Many vendors are offering 2 wire radars with process seal for level measurement. contact the vendor representative for more details. We have used emerson 5400 series radars in acid applications
Nikunj Jain
01/30/2011 9:48 PM
You need to refer with the supplier... what the suitable materials for radar level probe, Example, Monel, Hasteloy or stainless steel etc
We Stare Because We Care
01/31/2011 4:42 AM
in my company we have used ultrasonic level transmiiters for acid tank level measurements..... there is no problems at all once it is properly commissioned ....
01/31/2011 4:59 AM
in my company we are using ultrasonic level transmitters for acide level measurements... there is no problems at all once it is properly configured or commissioned .......
02/24/2011 6:29 AM
You didn't mention here which type of acid level you want to measure. i.e. H2SO4,HCL etc. Coz there are different types of materials used in the transmitter construction for different types of acid level measurements.
But
If you want to use a level transmitter (D.P.) for acid level measurement, then isolate the acid & transmitter using a thin film of teflon (ptfe) sheet in between them (which is easily available in the market). We were using the same isolation technic where i was working.
Register to Reply 7 comments
Anonymous Poster (3); Banana86 (1); lyn (1); masteryoda (1); nikunjjain (1)
