Previous in Forum: Continous Combustion Cycle ?   Next in Forum: Autoclave Cleaning
Assembly and Alignment Issues
01/29/2011 7:33 AM
I am masters in mechanical engineering student at the university of Portsmouth. I believe you can assist me to get a more broader view of a paper am working on so I will like to know how you can optimize quality in production of a complex machine system were you have lots of alignment and assembly to be done.
Re: assembly and alignment issues
01/29/2011 8:21 AM
One question, in one category is all that is required. Posting in multiple sections only wastes time.
Quality can be optimized by proper definition of machine requirements, adequate design and planning, complete engineering design and documentation and proper training of the work force.
You'll have to write your own paper. They used to call them research papers for a reason. They should call 'em cut-n-paste papers now. Nobody seems willing to do any independent research any more.
01/30/2011 11:00 AM
GA Lynlynch. Simple, concise, to the point and the outline of the complete paper. I suggest a internship at a manufacture of large equipment.
A good deed not praised holds behind it a thousand deeds yet undone.
01/29/2011 8:24 AM
I'm astonished that you've got as far as reading for a second degree when you apparently can't even read a simple set of instructions:
Tips for Posting on CR4:
  • Look for answers before you post. The answer to your question may already be on CR4.
  • Provide as much information as possible. Questions lacking detail won't get answered.
  • Give some thought to your post title. Don't use "Hello", "Question" or "Help". Be specific, e.g., "How Do I Install Replacement Brushes In My DC Motor"
  • Please stay on topic. Posts and comments should be of a technical nature and engage some aspect of engineering, science or technology.
  • *** Do not post the same thread multiple times ***. We will delete duplicate posts.
  • Include your country/region if needed. Some questions can only be answered "correctly" if people know where you are in the world.
  • Do your own homework. CR4 is not a homework cheat site.
  • Post all advertisements in Commercial Space. Select that forum from the list below.
  • For more tips see our FAQ.
Re: Assembly and Alignment Issues
01/29/2011 11:40 PM
If I read your question correctly, you wish to optimise quality production coming from a complex machine system where the finished item must be aligned at several work stations and a several steps of assembly must be done.
If, again, this is a correct interpretation, then it would be something not attempted in manufacturing facilities.
Simple assembly (placing label, filling, capping, coding and cartoning) is the target of current manufacturing practices. That should be the goal of engineers. Simplify.
We currently run a 137 units per minute, about 58,000 finished at the end of a 10 shift. And we try for simple. I can't imagine but our OEE would be worse than it currenty is.
I am sorry to be so pessamistic, but I wish engineers in my place would focus on simple and reliable instead of a lot of whirrrrring...then a red light....then a crash.
01/30/2011 12:14 AM
"lots of alignment and assembly to be done"
1. Use as many as 'self aligning' techniques as possible. eg: tapper shanks in drilling m/c.
2. Ensure the perfection. eg: laser tools.
Good Answers: 153
01/30/2011 8:16 AM
My favoured approach is to design the product so that it aligns itself when it is assembled. Machine to closer tolerances, add dowel pins, include slide fit mortice and tenons into adjoining faces. Also consider combining some of the components into a single machined part. You can't eliminate machining tolerance, but one machining tolerance is better that a build up of three machining tolerances plus an assembly tolerance.
A good design will take into consideration the manufacturing method as well as the component build up. A laser cut end frame will always be more consistent than one assembled from several parts. Eliminate procedures like welding and brazing which add stresses and distort the shape of the parent metal. Even laser cutting will create distortion when applied to thick metal. Use water jetting instead.
Another standard technique more commonly applied to machining, but equally applicable to assembly, is to clamp the work pieces on individual platens (assembly jigs) and then transfer to platens between work stations. The platens have dowel holes that mate precisely with each work station eliminating both set up time and alignment errors This method is generally employed on high value, high volume, items that can justify the cost of the platens. Google pictures of television assembly lines for an example.
All of the above depends on good documentation. Tell the supplier/manufacturer not just what you want but how you want it made/assembled. A design should be far more than just the drawings.
Register to Reply 6 comments
JAGwinn (1); jhhassociates (1); JohnDG (1); lyn (1); Randouli (1); yesyen (1)
