Previous in Forum: Food Grade Lubricants for the Food Manufacturing Industry   Next in Forum: How to Measure Paint Thickness on Vinyl?
12 comments
Motor Pedastal Axial Vibrations
01/30/2011 10:22 AM
We have a synchronous electric motor, 1040kw, 50hz, 3000 rpm. This motor drives two screw compressors coupled at both ends. This motor has both bearings on separate pedastals. Thrust collars are given on both end of journals at both end of rotor. This motor was running trouble free for last 25 years. Recently one of its journal bearing failed and all white metal was pealed off. We have replaced standard bearing supplied by OEM. After this replacement at one of the pedastal we are getting very high velocity(20mm/sec) in axial direction. Horizontal and vertical velocities are OK (1.5 and 2mm/sec res.) Please suggest how this can be rectified.
Re: Motor Pedastal Axial Vibrations
01/30/2011 10:47 PM
What type of coupling is existing between motor and compressor?
01/31/2011 1:35 AM
Both side gear couplings. Axial vibrations on driven equipments are also within 3mm/sec.
Good Answers: 32
01/31/2011 5:31 PM
My off the wall guess is that the bearing is skewed on the shaft.
Was the bearing pressed onto the shaft? How was it installed?
johny451
02/01/2011 1:50 AM
Thanks for the participation. Bearing outer shell is spherical in shape to take care of any skewness.
Good Answers: 67
02/01/2011 7:32 AM
Bearing outer shell spherical in shape may take care of any skewness up to some extent only. I suggest to check following aspects also for high axial vibration:
1. Is the alignment within the norm after replacing the bearing?
2. Please check the gap between two thrust collars, whether sufficient space for expantion is ensured.
3. Some times gear couplings get locked and give rise to axial vibration. please check for freeness and proper lubrication.
4. Check the tightness of bearing housing and foundation bolts.
More ever, have you analysed the causes for failuare of the bearing. May be the same cause (if not removed) is responsible for this problem and it may leed to similar failure.
02/01/2011 12:03 PM
Pritam, Thanks for your participation. Please note the the following: 1) Skewness if more, bearing will have rubbing marks on cross ends 2) If gear coupling is locked, Motor rotor is heavier then compressor and the induced vibration will be reflected on compressors as well. 3) Further, we are having vibrations on one side pedestal only. Other pedestal is as smooth as if motor is not running. 4) Bearing failure reason has been analysed. This system tripped due to power failure. Due to power failure oil pump stops pumping immediately while due to momentum motor+compressor rotor keeps on rotating. Slight debri if comes during that period it will peel the bearing and same thing has happened in our case. Bearing got peeled off and without noticing, compressor was restarted resulting in bearing failure.
Good Answers: 67
02/02/2011 6:50 AM
Mr Mukesh, You have not answered to the points 1,2 & 4 of my previvious post. Why do'nt you take vibration spectrum and analyse the causes?
The Bearing failure reason you have given is most common for turbomachines. You should install a small gravity oil tank to take care such evantuality.
02/02/2011 9:24 PM
In fact unkowingly these points got oversighted because no body will run tubo machinery without attending these three points.
Anyway, Yes Alignment is within norms, Thrust collar clerances are sufficient to take care of thermal expansion, and there is nothing left loose on the pedestal.
For your inf. problem is almost solved. We have added some weight to the pedestal to change its natural frequency and we got the positive results. Now Machine is running within normal limits.
Thanks a lot for all participants.
02/03/2011 12:07 PM
When gear coupling runs for long time in one particular set-up/position, the external gear works (digs) into internal gear a bit. For close observation, a tiny stamping could be noticed in the internal gear teeth. After an overhaul, the chance of these gears running in the same location is less likely. So a new position, the pair might, to start with, runs with a small linear contact. Of course, these pair of gears set-in more sooner than later. During this 'burning-in' period there could be high vibration, predominantly on the axial direction with one time rpm frequency.
08/22/2011 4:54 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
04/18/2012 11:16 AM
Check the coupling gap is ser correctly. Also check that the couplinh halfs are put togther correctly. They can go togther backwards and break the tip off the location device.
How is the alignmnet of the two machines?
Was the oil, based on your quote, "The fan was scheduled for new lubrication and the vibration was observed 1 hour after start-up." of the correct viscosity.
If you born poor its not your mistake but if you die poor its your mistake
04/18/2012 10:02 PM
Rajesh
What is the ref. of your reply? Have you gone through the thread contents?
Register to Reply 12 comments
electricaleng (1); Johny451 (1); Mukesh0861 (5); pritam (2); rajesh1986 (1); yesyen (2)
