Previous in Forum: Automotive Maintenance   Next in Forum: Noisy Air Cylinders
Weight Calculation Software
03/30/2007 6:58 AM
From 2D detail drawing, without converting these drg to 3D model is there any software available to find out the weight of the part..
Also posted in: also posted in Software & Programming
Re: Weight Calculation Software
03/30/2007 11:52 AM
Not sure what you really want here, but, GrafiCalc (or SectionCalc) at
http://www.inventbetter.com
May help
03/31/2007 8:41 AM
I've never checked it out , but eMachineShop might be what your after (?) . I think the idea is that a home designer can submit drawing/material spec for a production quote . The software download may include the facility you want. It's a long shot , but any port...
Kris
04/08/2007 3:49 PM
If you are using AutoCad you simply create a region of the cross-section and obtain the geometry's mass properties. Multiply the area by thickness or length, multiply by the density (.283 lb/in3 for steel) and voila, you have the weight. If other cad software doesn't do section properties you might try the section add on at the previously mentioned site.
"A job worth doing, is worth doing well" - My Father
05/04/2007 12:59 PM
Thickness =T Width=W Lenght=L
If all else fails T X W X L X .2833 = WEIGHT
Help me with the things i don`t know . I`ll try to help you with the things i do know and we`ll both get smarter
Kris (1); MADMACHINE (1); Randall (1); silver ghost (1)
