I have a 1920's to early 30's koken hydraulic chair. Its main problem is that once it is pumped to raise the height, the chair slowly drops back down. I pulled it apart down to the last bolt, cleaned all the sludge out ( the piston and cylinder look brand new), replace 2 worn springs ( one on the stem valve the other on the plunger valve), re assembled it with fresh 50 weight oil, and it still does the drop. It drops more slowly now but still drops. the other issue is that it has no brake in it. When I broke it all down, there was no brake block or evidence that there ever was a brake in the cylinder. would the lack of a brake block have any effect on the cylinder staying up or is it just to stop the spinning?
